RCU Forums - View Single Post - Mini Showtime, Convert to GLOW ???
Old 11-18-2007 | 10:00 PM
Dav0012
Default RE: Mini Showtime, Convert to GLOW ???
just for a comparison.
saito 30 weight set-up.
engine with muffler: 278grams
Fuel tank (dry): 41grams
Feather weight servo for throttle 9grams
Total 328 grams
Park 480: 87grams
40 amp speedy: 62 grams
e-flite 2100 li-po 187 grams.
Total 336 grams
Power 10: 122 grams
Total 371
Now i know people use a wide range of electric set-ups that may come out lighter, but the above is an interesting comparison. because as i stated earlier the only main weight difference is the added reciever battery and slight added wood on firewall for support. there is only slight differences in weight therefore power will be the only concern. Will the 5.03cc's be enogh to pull this aircraft, who knows, hopefully my maiden later in the week will test this out. in theory the plane should come out around the higher stated 800gram mark, but from what ive heard this motor pulls 1.3-1.4kg static thrust. correct me if im wrong but that sounds like a healthly almost 2:1 ratio, or a 1.75:1 or something like that i'm not sure of the exact calculation.
