Originally posted by KyleSch
I don't think its even possible to put more air into the engine than it takes normally as it can just go right out the other side. Even if it did work it would just raise the compression, nothing you can't do by just removing a shim.
Thats not really what they are designed to do. They are there to catch the fuel/air backwash when the piston goes down and to give an immediate supply before the carb can provide the fuel/air. They hook-up between the crank and carb, so they are independant of the carb's throttle position. In any case, I would imagine that they would be standard on all of the high-end engines if they made much difference, but I generally only see them on the thunder tiger low-end models.
