RE: 8UAP glitch problem
Keith,
Is your 8U the "Super" version? If so, you can move the second aileron servo from channel 6 to channel 5 if channel 5 is not being used. Hopefully, if the problem is on Ch.6, moving the second aileron servo to channel 5 would solve the problem. You can do the switch to channel 5 in the "PARA" section of the menu. Like I said though, this can only be done on the 8U Super transmitter.
Jesse
