Tail Rotor Blades Thrown
How loose are your tail rotor blades in the grips? I've set mine so that they are almost loose enough so that they will slip down when held level. If they are really tight, then you can partially strip or weaken the bolts that hold the grips on when your blades hit some grass. If you fly off of a grass field, hitting the grass is going to happen no matter what. Your blades shouldn't hit the ground itself though.
