RCU Forums - View Single Post - Com. Flash
Thread: Com. Flash
Old 11-20-2007 | 11:46 AM
rhklenke's Avatar
rhklenke
My Feedback: (24)
Default RE: Com. Flash
I finally got mine dialed in (and got used to it), and it flys great! Mine has a 120SE engine in it and I love the plane and the engine! If you go with an engine bigger than a P-80, get the wing tank. If you want to fly off of grass and don't want to go with the trailing link gear, simply modify the main gear and struts to accept 8mm pins instead of the 6mm. The 6mm pins WILL break on grass - its not a matter or if, but when. Its a simple mod. and then you are all set.
See here for the parts necessary for the mod:
http://www.rcuniverse.com/forum/fb.asp?m=6361459
Bob
