Com. Flash
#51
Eric Clapp recomends only using half of the bypass for the Artes engines anyway so all should be OK. Just make sure there is no loose stuff in the plane that can get sucked into the engine or clog up a FOD screen. Some will claim a slight loss of speed without the bypass so you may not be able to go 250mph.
#53
Can robart 630 retracts be used in this airplane? I am sorry I have not read the thread, so if its mentioned anywhere, I apologize in advance for repeating it. I have a set of rookie 2 prolink struts as well that I can use in this plane should i decide to buy one.
