RCU Forums - View Single Post - Problem with a bogging motor
Old 11-21-2007 | 12:10 AM
Druss
Default RE: Problem with a bogging motor
you might either have too much pinion (try a 10t or 11t) or you might have too much pitch on the blades at a low rpm. since the pitch is easier to change try lowering the pitch curve to see if that helps.
