RCU Forums - View Single Post - Y/A Kit HELP Please
Old 04-02-2003 | 02:32 PM
tomcatman's Avatar
tomcatman
Default Y/A Kit HELP Please
Hi. First of all, the parts outlined on your list are very basic misc. parts which you should be able to obtain from any local hobby shop. I strongly feel however, that you are making a big mistake with your choice of gear. You have the Y/A F16 "C" model, which can accommodate the scale main gear assembly that Y/A sells for this model. The aluminum (and very light) main gear folds right up into the fuselage just like the full scale Falcon. I too have that model, but I have the "A" model, which can not use the scale gear set up, unless this has been fixed with the newer kits as mine is about 7 or 8 years old or so. Anyways, good luck. If there's anything else I can help you with, let me know.
