RE: Engine storage oil or not?
Ok,let me ask you this....How do you use oil? Do you just squirt a few drops in the carb and stick my starter to it for a couple seconds? Should you remove the glow plug? And will it gum up the carb after sitting along time? And does it matter if you run the engine before oiling it or can you just put in the oil anytime? And is it good to re-oil every couple weeks or would that gum it up too much??
Thanks for taking the time on my dumb questions!
