Hello Glue happy Prole,
Great post,
I will try both of them as soon as I can find them, and if I can't get them here I will order.
You forgot the most important part, and that is if you use CA glue you will forever be able to identify your airplanes, due to the finger print that is left when you tear the top layer of skin away and leave it glued to some part of the plane.
Yes,,,, How many out there have felt the heat of setting CA and knew that the little part that you are holding may not be glued to the plane but it sure is glued to you!!
I think someone should name that particular scream, the one that is used in that split second realization that your trapped and will have to gnaw off your finger tip to escape.
Or maybe a name for the moan, of those who are a little tougher and have a callous for a buffer, but will have to cut off their last layer of cushion.
My debonder is a joke, I think it is light salad oil. It should include pain killer, at least that would be useful!!
Just rambling, and thank for the great info,
The CAD student,
MR Flyer57
