RCU Forums - View Single Post - Spitfire
Thread: Spitfire
Old 11-23-2007 | 05:47 PM
  #36
js3
Default RE: Spitfire
Perhaps another reason the later marks aren't modeled as often is the complex landing gear. With the Griffon power plant came a larger prop so the gear legs needed to be lengthened.
Has anyone ever acurately replicated this gear action in a model?
The landing gear legs were also lengthened to provide sufficient ground clearance for the new, larger propeller; a system to compress the legs by 8 inches as they retracted and re-extend them upon lowering was devised to overcome the problems posed by the lack of room in which the longer legs initially had to retract.
