RCU Forums - View Single Post - Pentathlon Kit Build
Old 11-24-2007 | 10:02 AM
  #33
flyintexan's Avatar
flyintexan
Default RE: Pentathlon Kit Build
The fuselage frame and formers are built on a flat surface, aligned on top of a straight line. The frame work (known as the fusebox) is built upside down. The fusebox top consists of three pieces that are joined together (small balsa scraps) over the construction line. This is the full length of the fuse, minus the rudder. Secure this to the building surface (tape is fine).
ID:	810573   Click image for larger version
ID:	810574   Click image for larger version
ID:	810575   Click image for larger version
ID:	810576   Click image for larger version
ID:	810577   Click image for larger version
