RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 11-25-2007 | 09:16 AM
  #584
DamBo's Avatar
DamBo
Default RE: DL-50 engine
Hey guys
Just a little update on my extra progress. I know that this is a DL-50 forum, but that is what is going in it. When I received the kit the fuse had some cracks in it, a hole in both boxes. A replacement one is on it's way. I started assembly to see how everything is going to work out. I still have to work out the throttle and choke linkages because I would like to run the engine a little on the fuse, but since I have not epoxied anything together on the engine mount (it is just screwed) until the new fuse shows up I will wait and be safer. Do you think that HS645MG HT 133oz/in will be enough for this, or should I go more and digital?
ID:	811357   Click image for larger version
ID:	811358   Click image for larger version
ID:	811359   Click image for larger version
ID:	811360   Click image for larger version
