RCU Forums - View Single Post - Flair Puppeteer Trust Angles
Old 11-25-2007 | 12:50 PM
  #381
glen pratts
Default RE: Flair Puppeteer Trust Angles
Thanks guys, Ive been offline for a little while and not been able to respond. Sounds good about using thinner balsa for the fuselage. Im defenitly going to do that. Ive heard that the pup flies well even if you need to add weight at the front. However its always nicer if you can avoid doing so. Ill start building after christmas the box is still under the bed till i finish the xtra wot by Chriss Foss. Ill try and start a thread showing the construction now that i have a digi cam. Thanks Jim and Bassman. Do you have any pictures of your pups?
Kind regards
Glen from the mighty Rock
