RCU Forums - View Single Post - Need Robinhood 80 modification info/pics
Old 11-25-2007 | 05:06 PM
  #35
Kweasel
My Feedback: (29)
Default RE: Need Robinhood 80 modification info/pics
Make sure the front and rear wing saddle mounts are better tied to the vertical members on the fuselage sides. I used simple plywood gussets and they worked fine. If the wing bolt holes are in a solid block then convert it to twin nylon bolts front and aft, or use a single metal bolt in a big washer and a T-nut. I have owned three RH80s with nearly every size engine from a .60 to 1.8. Make sure the control surfaces are stiff and have fun.
