RE: CHRIS' MODDED REFLEX W/ INSTRUCTIONS
Looks great Chris! How does it fly? Range has been an issue with both of my reflex's. The longer antenna looks like the range issue is solved. Did you mod the tx. I have read that the thruster stick can be made 360 deg by removing something on the inside. I want to try that but... so far no nerve! Oops , maybe it was you that talked about the tx mod? Guess I should look for a suitable fuslage before I cut mine up. The cx2 canopy looks great! It will be tough to actually reduce weight by changing the fuselage since the styro is ugly but fairly light. Thanks for the detail & the pics. AWESOME!
