RE: Saito 82-Sundancer
I put a YS .63 in one and you will have no problem putting in an .82. The YS install went perfectly. Do not, however, use the supplied spinner. It will fall apart quickly. a 13x4 APC wide blade prop was used with the YS and you should run a 14x6 with 30%. All up weight was 5.875 lbs.
Adam
