ORIGINAL: ldgasp
I read of specific engine temps you car should run. How do you test these temps and what is the ideal range? Also, how do you tell the proper carb settings?
200-230 degrees are good temps don't try and get it exact you'll go crazy trying. The spit methode is a good methode if you don't have a temp gun.
