RCU Forums - View Single Post - CHRIS' MODDED REFLEX W/ INSTRUCTIONS !!UPDATE!!
Old 11-26-2007 | 05:56 AM
cx2cp+'s Avatar
cx2cp+
Default RE: CHRIS' MODDED REFLEX W/ INSTRUCTIONS
hmmm...you've halfway made a coaxial-bladed cheyenne! - cool !
The Cheyenne was, to say the least, a rather exotic-looking aircraft. The forward end of its long and narrow fuselage was dominated by an outsized segmented canopy covering a tandem, two-seat cockpit, while the tailboom supported a large ventral fin, a conventional anti-torque tail rotor, and a decidedly unconventional pusher propeller. A pair of small, low-set stub wings fixed to the fuselage sides contributed to the Cheyenne's hybrid look, as did its retractable, wheeled main landing gear. The AH-56A's ungainly appearance was deceptive, however, for in flight the craft was amazingly agile and extremely fast. The Cheyenne's impressive performance was the product of an innovative propulsion system built around a 3435shp General Electric shaft turbine engine. This powerplant drove a rigid, four-bladed, gyro-stabilized main rotor, the tail-mounted anti-torque rotor, and the pusher propeller at the extreme end of the tailboom. During vertical and hovering flight all power was applied to the main and anti-torque rotors, while during forward flight all but about 700shp was shafted to the pusher propeller. In forward flight lift was generated by the stub wings and windmilling main rotor, and in absolutely 'clean' configuration the AH-56A was capable of sea-level speeds in excess of 400kph. - http://www.aviastar.org/helicopters_...k_cheyenne.php
edge
