RE: crock pot cleaning
I also like to pull the piston sleeve, piston, and crank out and then put everything (all the metal parts that is) in the crockpot at once. This allows you to fully inspect bearings after the cleaning, as well as make sure you have ALL the antifreeze out of the motor before reassembly.
Brad
