RE: Question Ref Spektrum fades/frames figs.
Hi Geoff, I have been flying two models over the last three days with Spektrum AR9000 receivers with twin remotes. Again my BobCat was perfect with not a single frame lost. On one flight A +B receivers both had under 20 fades and L + R under 10 ! The very next flight A +B had almost 200 fades and L+R almost 100 each, still no frames lost and no hold. Rock solid and stil not a single frame lost in 25 flights to date !
I also flew my Savex L39 . I was a bit concernerned with this small model with all the equipment in such a small space. I put one remote Rx in the wing as a precaution. Results amazing, Fades are VERY low in ALL receivers, (under 10 for ALL receivers on one flight) no holds and only 4 frames lost and that probably as a result of walking around the other pilots in the box and blocking the signal after landing.
This is working to perfection for me, amazing stuff.
All we need now is 12 channels, or more, and data acquisition and programming as extensive as the Weatronics !
Regards, David Gladwin.
