RE: Bobcat 50 Assembly Question
If I do it that way there would be significant play between the landing gear wire and the wood since the grooves of the individual wood pieces are the same diameter as the wire. The other problem is that it would be impossible to insert the large piece inside the wing once it is glued to the smaller one. The small piece fits perfectly on the upper part of the wing so I assume that the larger one should go under the small one correct?
