RE: Pentathlon Kit Build
The rest of the formers can be fitted to the fusebox base and glued in place. Make sure you are putting them in upside down. The firewall can also be glued in place. Notice I used some scrap 1/4"x1/4" balsa to reinforce the joint. A ply ring is also supplied to be used as a blind nut/motor mount support later.
