RE: Pentathlon Kit Build
The fusebox bottom can now be fitted to the assembly. Dry fit first and make sure this piece fits properly. I used epoxy on the landing gear plate and firewall areas when attaching the fusebox bottom.
The stab doublers can then be glued into the fusebox framework. Again, dry fit and make sure it will go together correctly before applying glue. Make sure the doublers are facing the right direction (notice the rear edge of the doublers end flush with the end of the fusebox).
