RCU Forums - View Single Post - the hyper st PRO thread!
Old 11-26-2007 | 11:01 PM
  #262
bentgear
Default RE: the hyper st PRO thread!
Stock shocks are big bores by last years standards. Yes you are spoiled by the LST shocks. You will most likely find that you will need to rebuild more often than the LST shocks. If you stop and look at the suspension you will notice that unlike the LST the front and rear are very different, that means shocks of different lengths. Try dropping the rear down to 45 wt and it will feel better.
Did you find a cure for the up and down movement in the steering that was bothering you? How much movement is there by measurement?
Ed M.
