RCU Forums - View Single Post - Xtreme 1st Impression?...?..!!!
Old 11-26-2007 | 11:07 PM
S!N!ST3R RC hObbys's Avatar
S!N!ST3R RC hObbys
Default Xtreme 1st Impression?...?..!!!
Today I recieved my xtreme/MH heli upgrades. I recieved the grips (MH)
and the extended upper head by xtreme. When First saw the grips and parts I
said...wow, I like. But as the rebuild began....SO DID THE PROBLEMS!...
I began with the swash, then the upper head, and trying out the stock flybar for
any problems...Yep, the xtreme upper extended head does work with the stock
flybar. As I started putting the bottom grips on, I noticed that the small washers that
fit around the grip extentions were gunna make the grips to much of a tight fit, so tight that
the grips wouldnt move freely...so I took them off and tryed without the washers, it worked.
Next to the top grips, they too were also over tight and the flybar was stuck completly!!
By this time I was not getting along with the heli at all, lol yea not good...so I took the grips
back off, and took the washers out, it worked, but when they were placed back on without washers,
It was still to tight, the problem was that the Xtreme upper head bars that hold the grips on were to long,
and the grips were to tight without being free...dont get me wrong...they fit, but very tight and no
play for the flybar. So I used the dremal, and cut just a bit off of the bars, IT WORKED..now with only
the blades left, I started mounting the MH (black) blades..they slipped in fine, but one or two of the
blades were much more loose than the other two. Anyways, after trimming and doing ajustments
for an hour...yea...an hour!...It slowly starts back to hover...thank God...
When I got it just about into trim, my battery fails, just stops lol, dont know whats going on, but
I cant fly now...So My overall 1-10 on the upgrades, ill give them a 4. Just because of the trouble
having to get back into correct trim, having to cut the upper head, and the washers not working as
they should. Also, my heli didnt have as much lift as it should have, and didnt lift with the MH blades
worth a ***** and its now got a hell of alot vibration...seems over rated to me...but im sure that when
you pay100$ smacks for somthing to bolt right on, seems it would, but its all good as This is just a fun
hobby and i love the looks from the grips and upgrades just as well...but If your looking to buy the cx2 upgrade...
I say until your bored as hell of the heli, then sell, or upgrade for more trimming practice. well said.
So after the last flight, id give the stock cx2 a 8 out of 10, now a 4, but ill just have to work on my bird a bit more,
so maybe it will start flying better.
Happy flying to all!!!
