u have used this green foam in ur 3d model. I have seen the same stuff in decorating flowers , where the flower stems r poked inside this foam which has been soaked in water earlier. I don,t know the technical name for this foam, can u tell me what it is called. I know it is not thermocole because it would degarde after applying resin.
I thought u would be using polymer clay to design. Have u used polymer clay in any of ur projects?
thnx for ur tutorial!
looking forward for more
regards,
Pradeep
