RCU Forums - View Single Post - the hyper st PRO thread!
Old 11-27-2007 | 06:05 AM
  #264
HerrSavage
Default RE: the hyper st PRO thread!
OK, next problem... The Mach backplate seems to require quite a bit of extra space over what is offered by the engine mount...
I was hoping 2x of these little brash washers(which I was planning on using with the Picco 28 in the LST2...) on each screw, but I would need to use four on EACH screw.. Furthermore, I would need to use 20mm screws for the mounting to the engine, instead of 15mm... I have neither enough washers, nor enough 20mm screws...
What would be the best solution here?? Go get some more washers and screws?? Try to find some extra spacer plates, or what... The difference that needs to be made up is a good 3mm.. Is that too much to raise it??
Here's what it looks like with enough spacers for the engine-mount to work..:
