RCU Forums - View Single Post - Saito 50 running problems
Old 11-27-2007 | 07:49 AM
djsdog's Avatar
djsdog
Default RE: Saito 50 running problems
Well I bought a new glow plug for the Saito and I'm gonna reset the valve clearence per your suggestions (thanks), set the low idle back to factory setting and test run it again. If I can get it to run up to full speed correctly I'll put it in the Cub and lift off.
I need an engine cowl for the Cub but may fly it without a cowl to maiden it, (see how the Saito does before fitting a new cowl to it).
I looked at the Goldberg site and mine does look like their 76.5" Cub however my wingspand is 68.5". Someone said it may have been built as a "Clip Wing Cub" and the Goldberg websight did not say what the wingspand for clip wing is?
Oh well, for $75 already built with flight pack how could I go wrong!!!!
Denny
