RCU Forums - View Single Post - Question Ref Spektrum fades/frames figs.
Old 11-27-2007 | 12:55 PM
asimace
Default RE: Question Ref Spektrum fades/frames figs.
ORIGINAL: Airforce7
I'm a new user of the AR9000 Rx and Flight Log device. Over the weekend I got some interesting data from the Spektrum Flight Log. On one of the flights I got over two hundred fades on A and B antennas and nearly two hundred for F (Fades), which resulted in 3 Holds. On another flight I also notice this reading "b ---" as I cycled through the logger. What would cause this reading? Also, when I get holds (failsafes), what exactly is happening to the Rx/Tx link? I didn't notice any loss of contact with my aircraft. I have not once moved my setup and have had flights with no more than 2 or 3 fades on any of the antennas.
Hello... did you by chance do a range check before the flight, pressing down the Bind button behind the transmitter? If you do a range check and then you fly without cycling the power or the receiver the flight log will show the numbers it recorded during the range test that are usually higher than those recorded during the normal operation...
Remember to always cycle the power of the receiver after a range check to reset the numbers of the flight log.
This might help?
Ciao!
Mauri
