RE: Thunder Tiger 36H Assembly Question?
On the 36 . . . .
The piston has a shoulder in the front to retain the piston. In the rear, there is just a straight hole. You can not use a nylon pad because the wrist pin hole comes half way across the rear Schnurle port.
I have pads, that would be easy.
