RE: Question Ref Spektrum fades/frames figs.
Mauri, your right you can cycle power on the Rx and reset the Flight Log. I'm pretty sure the high numbers I'm seeing on the logger are a result of both low flying to the ground and from violent maneuvers such as fast rolls. Everybody seems to be having great success with Spektrum, but there are little anomalies that I come across on the bench and every time I come out to the field with it. I will continue to test the AR9000 some more before putting it in my Rafale.
