Is it okay to mount my servo horn this low on the rudder? I could go a little higher w/ a little more work.
Check it to make sure you have clearance for however the tail wheel is mounted. You don't want the horn's bolt(s) trying to pass through a piece of music wire or other hardware bedded in the rudder.
