RE: jato help
the low speed needle is hard to set as well as hard to get to. first clean the low speeed needle with air compresser or a toothpick. once that is clean you should be able to see a black ring on THE INSIDE of the whole component.( do not take apart the needle )the needle should be even with this small ring. for a better explanation go to traxxas.com and look at jato information
