Want to build first kit
It is a great plane! No pun intended. I like the 60 way better than the 40. Both are good, but the 60 is more stable. It might be a bit much if you have never built anything. It is also fast if you are not very advanced. If you get someone that knows what they are doing to help you build and fly it, you won't have any troubles. It is a good bird.
Hope that helps.
