Lots of radio questions!
Not quite sure what you are asking here. The crystal is in both the transmitter and reciever. If you use a different transmitter, it must be the same brand and freq to work. Some will work with others like hitec and futaba. If you want to use the same trans and different rec, then you need to consider the same thing, brand and freq.
