Originally posted by Jim Schwagle
The least expensive are the ones from Polk's Hobby and Hitec makes one also. The Hitec one is $225 or thereabouts for transmitter only. It has what is called a Spectra Module which allows you to select the frequency you're transmitting on. Check the web, you can find both.
Jim,
I think you've overlooked the fact Dan is talking about RC cars / trucks. He probably wants a pistol style of transmitter. Hitec makes a couple pistol grip versions, and at least one of them should support the Spectra module. The Tracker II from Polk's is a 2 stick version.
