RCU Forums - View Single Post - Nitro models pusher Bobcat?
Old 11-29-2007 | 08:23 PM
  #2655
Stick Jammer
Default RE: Nitro models pusher Bobcat?
Original: marktur
So Bill - it's EASY. Just unbolt, and rotate 90 degrees. Bolt it back on. Plug in your started red-to-black (opposite) and start her up! (Don't forget to put on a pusher prop).
I just went back a few posts and caught this. You don't want a pusher prop if the engine rotation is reverse, which is basically the reason for doing the engine mod. I think you meant; Don't forget to turn the prop around. A standard prop has to be installed backward from the norm.
