Yep, Shaun---these planes are keepers!!! I hate to use the term the "ugly stick of jets" 'cause this plane is not ugly at all. I only experienced a high speed stall one time at the bottom of a loop that was a little tight. Luckily, there was enough altitude to recover. The best thing to do in case of the high speed stall is to just release the sticks. There is usually enough speed for the plane to start flying straight again.....However, the plane could be flying straight but who knows what attitude it will be in!!! The only problem is if you run out of altitude or loose orientation to totally recover.
Are you insane?!?!?!
A P-80 in a Heinelman (sp?) Hotrod??? She ought to go like a bat outta you-know-where!!! I hope the wing loading doesn't get too high. You don't have an MW-54 size engine to put in her???
Kevin
