ORIGINAL: i3dm
BillS, you sure the ST 90 has a removeable front housing ?
The older ST .90 made in Italy had a removable front housing. Larger ST's also had a removable front housings. I think the sizes were 2000, 2200,2500 and 3200. Also Moki has a removable front housing.
Measured intake timing on ST .90 (standard rotation):
Intake opens: 135 degrees BTC
Intake closes: 50 degrees ATDC
With rotated housing and reverse rotation the timing will be:
Intake opens: 140 degrees BTC
Intake closes: 45 degrees ATDC
Intake timing indicates the engine should run successfully in reverse.
Measured weight ST .90 with torpedo muffler = 25.3 oz.
A 12 inch diameter prop might be somewhat small.
Bill
