RCU Forums - View Single Post - Pershing reporting for duty!
Old 11-30-2007 | 03:39 PM
shadopilot's Avatar
shadopilot
Default Pershing reporting for duty!
Well, here it is after many hours of work. Stock electronics.
Mods include:
Sandskirts removed
Periscope brushguards out of metal
Metal .50 cal. storage brackets
Metal commanders vane sight
Metal pins in tow hooks
Extended barrel
Holes in trunnion axis filled
Gunners periscope and mantlet machine gun holes reworked
Bow .30 cal accurized and LED placed behind it
Antennea moved to turret top
Second antennea added to turret top made from fishing lead wire from Walmart. A role of this stuff will last a life time. Make sure to curl over the tip because... well.. you could take an eye out!
Holes drilled in the engine crane/hoist brackets
.50 cal. moved to searchlight mount. ( OK, so its a field conversion,my commander needs personal protection.)
The .50 was a project in itself. The barrel is drilled out, cooling holes drilled out, cocking handle scratchbuilt out of metal, ammo box replaced with a Ultimate Soldier version with ammo, scratchbuilt recuperator on the cradle, scratchbuilt front sight hood, ammo box moved to correct positon..
All painting and weather was done with my airbrush. The commanders periscope glass was done with some greenish/blue and then several coats of Future. The exhaust was done in rust color paint and mixed with backing soda. The decals were applied ontop of a coat of Future then Microsol and flatcoated. I'd like to thank the 2 guys here who sent me the extra decals they had. I don't remember who you were but I couldnt have finished it wi8thout your help. Many thanks!!
