RE: Engine help needed
sounds as if the idle screw is right open, or the high and low speed needles are lean as buggery.
Download a manual of of OS website and get the factory settings, set the idle so the gap in the carb is only 1 to 1.5mm, and u shoyld be good to go, once u have the factory, u can start tuning the motor till it runs good
