ORIGINAL: CrateCruncher
Abu, I thought I noticed a Nieuport fuselage in one of your recent Snipe posts. What scale is it and how did you do those elevator hinges?
It's a rather convoluted tale but here's the (semi-)short version: a couple of years ago I wasn't doing any building because I figured it would just be too hard here in Japan. But then my balsa addiction got the better of me and I said to myself "well, maybe just something fun and easy" and the Nieuport 11 structure looked simple. I had a set of the Joseph Nieto drawings so I enlarged those on the office copier to the size of a pot I was going to use for a cowl. I think it's roughly 1/6 scale but might be a tad bigger. And so I started building right on the drawings -- just to see what would happen. I got quite a ways into that build when I figured I really needed a practice plane (sound familiar?) and bought a Flair Legionaire and the build sort of morphed into the Legionaire. I was coming to the end of that when Chris offered me the Snipe and so both Nieuport projects have been sidelined for over a year. Now with a couple of other projects on the horizon with Chris, I'm not sure when I'll get back to the Nieuports.
http://www.rcuniverse.com/forum/m_29...tm.htm#2904955
But then I could probably have the Legionaire ready in bare-flying state in a couple of weeks.
Your aluminum outlines look great and I thought about it but chickened out because there are reports of the Proctor plane somersaulting over on its back occasionally. My only concern with aluminum is that it might bend out of shape when the plane goes over.
This is a fair concern. I was just having a devil of a time doing the laminations and wasn't at all happy with the result I was getting. The Snipe uses the lamination method on the stock rudder and elevator (with the laminated curves glued on either side of a thin balsa core). But I ended up making my own early-production rudder out of bamboo.
Edit: You clever dawg, the hinges are plastic tie straps, no?
Yep. They were after all called "strap hinges"! I'm still testing these but it looks hopeful. Note that it's necessary to add a spot of epoxy at the point of final attachment to secure the strap to the aluminum ring.
