RE: Engine help needed
Also, on engine mount screws, you could grind off just the head of the screw. Then when you take the engine off, it leaves a stud sticking up. You can easily grab this with a pliers to remove it. I would try cutting grooves first, though. Like scottywilkes suggested.
