Would this engine fit in the nemesis? With the stock bell crank and all just bolt on and go?
http://www3.towerhobbies.com/cgi-bin...?&I=LXPEB9&P=7
I ask becuase it seems to have a lot more rpm then the NX-76 but it dose not say how much HP it has. Do you think this engine would be better? It is slightly bigger and has more rpm?
NX-76
Displacement: .46ci
Ports: 3
Rear Exhaust
Starter Type: Pull Starter (Try CEGG70358 Roto-Tech for electric starting ease!)
Carburetor: 2 needle slide
Crankshaft: SG shaft
Piston / Sleeve: ABC
Horsepower: 5.0hp @ 23,000rpm
Application - 1/8 Offroad Trucks, Genesis, Nemesis
AXIAL
Displacement: .32cubic inch
Maximum RPM: 34,000
Bore: 19.5mm
Stroke: 17.5mm
Piston/Sleeve Construction: ABC
Heat-sink Head: Green or Gray Anodized Machined Aluminum
Carburetor: 9.0mm Composite Slide Carburetor (includes optional 8.0 & 8.5mm venturi’s)
Carburetor Adjustments: 3 Needle, Flush Settings
Case: Silver Aluminum, Rear Exhaust
Connecting Rod: Dual Bushing
Sleeve: 8 port
