CEN Racing This forum is to discuss all CEN Racing products.
Axial .32 Spec 1S
Old 12-01-2007 | 04:21 PM
Nick2618's Avatar
Default Axial .32 Spec 1S
Would this engine fit in the nemesis? With the stock bell crank and all just bolt on and go?
http://www3.towerhobbies.com/cgi-bin...?&I=LXPEB9&P=7
I ask becuase it seems to have a lot more rpm then the NX-76 but it dose not say how much HP it has. Do you think this engine would be better? It is slightly bigger and has more rpm?
NX-76
Displacement: .46ci
Ports: 3
Rear Exhaust
Starter Type: Pull Starter (Try CEGG70358 Roto-Tech for electric starting ease!)
Carburetor: 2 needle slide
Crankshaft: SG shaft
Piston / Sleeve: ABC
Horsepower: 5.0hp @ 23,000rpm
Application - 1/8 Offroad Trucks, Genesis, Nemesis
AXIAL
Displacement: .32cubic inch
Maximum RPM: 34,000
Bore: 19.5mm
Stroke: 17.5mm
Piston/Sleeve Construction: ABC
Heat-sink Head: Green or Gray Anodized Machined Aluminum
Carburetor: 9.0mm Composite Slide Carburetor (includes optional 8.0 & 8.5mm venturi’s)
Carburetor Adjustments: 3 Needle, Flush Settings
Case: Silver Aluminum, Rear Exhaust
Connecting Rod: Dual Bushing
Sleeve: 8 port
Old 12-01-2007 | 04:24 PM
Nick2618's Avatar
Default RE: Axial .32 Spec 1S
i noticed teh axial says it has 3 needles. So what are they? I know there is a HSN LSN. So did the add a middle one to make tuning even harder?
Old 12-01-2007 | 04:38 PM
Foxy's Avatar
Yes, it does, its called the midrange adjustment, and it's not actually a needle, it's the opposite. The low speed needle slots into it. Anyway, don't need to touch it til you get more advanced at tuning, but what it basically does is move the position of the fuel delivery within the carb. It's important if you ever do play with it, that you make equal and exact opposite adjustments to the low speed as you do it, otherwise you're just detuning your low speed. It's easy to get an engine out of whack this way, be careful.
