RE: cant get esc to arm with dx7
You say you disabled the bec. I assume you have some other source of power to the rx? If not then there's your problem. It seems too simple but hey...I have done worse. Kevin
Also try to make sure your throttle is at zero when pluggin gin the battery. Then slide the throttle to full for about 3-5 seconds. Then slide it back to zero and wait for the beep. Kevin
