Aggressor 1 / Sport Shark control settings from 1986 manual:
Flap - 30 Deg. (measured at upper surface, use flaps on landing only)
Aileron - 1/2" up, 5/16" down (measured at T.E. adjacent to flap)
Elevator - 1/2" up, 3/8" down (at T.E.)
Rudder - Not specified
C.G. - 2 1/ 2" behind leading edge of belly hatch (works out to 5 1/2" back from L.E. at upper surface root).
Note: It is recommended that the model be set up for balancing with the landing gear extended and fuel tanks empty.
Weight should be about 10 lbs.
I would be happy to send you a copy of the manual if you e-mail me. BV has some good information on flying tips.
Tom
