RCU Forums - View Single Post - Saito 50 running problems
Old 12-02-2007 | 01:08 PM
  #33
iron eagel's Avatar
iron eagel
Default RE: Saito 50 running problems
You want the mid point of the tank to be about even with the spray bar of the carb. Unless you use a uniflow 3 line type of setup for the fuel feed. Which is what I have in my cub because the engine is inverted and I can not set the tank that low.
Where you have a back hoe, and plan to make your own runway, perhaps you might want to consider setting up your own charted flying site...
