There's not much out there in a 60 size high wing tail dragger?
You may have to take a smooth flying Hobbistar 60 high wing plane and convert it to a tail dragger?
You will need to put a doubler with corner braces in the fuselage floor right behind the bulkhead that is at the front of the wing.
Fasten an aluminum gear to this this doubler.
Add a plywood doubler to the rear with a Dubro 60 size tailwheel bracket. Make a new wire for the tail wheel that extends up the rudder hinge line and fastens into the rudder.
It'll make a great plane. that is not overly expensive.
http://www3.towerhobbies.com/cgi-bin...star&search=Go
